Smart drive 708. Fill on cold water but not on hot????
Take the hot hose off the back of the machine, point the end into the sink tub & turn hot tap on. If you get a good water flow then tap is okay. If water will still not enter machine when you select hot wash then either the inlet valve is faulty or the main control board has a fault and not switching inlet valve on.
Problem in hot water tap
hot water solenoid not activating to let water in
to prove either switch the hoses on the taps and press cold water wash
that proves the tap
then press hot wash and that proves the solenoid
