You may need to move the needle position left or right. Try a different stitch length. If the ruffler foot is installed correctly and needle is in the correct position this should not happen. It is hitting left/right/forward or back of the ruffler needle space?
I'd say the click track starts from exactly when you hit play even if you've hit play not right on the beat. There might be a setting or preference that can fix this.
Try rewinding back to be right on the beat and see if it syncs with the click
The "replace drum soon" indicater is a warning for you to have a new replacement drum "on-hand". Soon the display will change to "REPLACE DRUM" AT WHICH TIME THE UNIT WILL STOP PRINTING.
When the new drum cartridge is then installed...the REPLACE DRUM indicator will be reset. DO NOT replace the drum before the machine says to.
the sound you hear is the motor trying to start.reach in drum and turn clockwise 1 revolution.try to start it again,if it starts your motor is starting to go bad and will have to b e replaced soon.if you canrt turn thje drum you probably have something stuck in blower below lint filter .hope this helps .please rate my response:)
A quick test. Switch off power then remove outer cover. Look for the transformer. remove the two wires connected to the primary side. Note, do not toutch anything else. power still sitting on the cap. With those two thin wires disconnected, make sure they are not toutching each other or leaning on the metal frame. Set a program that has been a problem and let it run. If it still stops and does what its not supposed to do, your board needs replacement.
What you need is 2 unlatched switches 1 for the stop start function and one for the drum fill function. I bought mine from my local music shop for £15 ea
I have not personally played this version of SmackDown!, but in others that I have played, DQ stands for disqualified. Technically, it is against the rules of wrestling to hit someone with a chair, especially in an official belt match. There is no way of getting around this without cracking the actual game programming.
You need to get mini-mushroom on world 1 lvl 4 then do it again so that you have it in your invintory
then go to lvl world 2 and defet world 2 boss then you should have lvl 4 unlocked!!!!!!!!!!!!!!!!!!!
