Question about Jet 3 Ultra Power Chair
Will not turn on after charging
After charging the red and yellow lights light up and the green lights come on. Then the green lights go off and the red and yellow lights constantly flash. This cycle continues until the unit is unplugged. When unit is unpluged from outlet it won't turn on.
    Problem Solver:
  • 17 Answers
Sounds like it's time for new batteries.
Posted on Sep 22, 2009
SOURCE:
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
Pronto M6 chair will not work. When the power switch is turned on, the LED light flash Red followed by three Green. I can't find what this error code meas.... Pls Help thanks Phil
Phil the red means battery is low and the green is a speed limit code because of the low battery if you have charged your batteries and you still get the red then you need to check the charger after charging all night does the yellow light on the charger turn green? if when you first plug in the charger if the red light is on and the other light is green then there is a problem with the wiring or connection to the batteries from the charger and you aren't charging the batteries. if when you plug the charger in and you get a red and yellow light then the charger is working but you don't ever ge a green light and the battery level gauge is still showing red then you need to replace the batteries Hope this helps
Apr 12, 2011 | Invacare Supply Group Pronto M61 Standard...
How do I know when the chair has charged? I see one red, two green, two yellow lights on.
If you have an off-board charger that plugs into the joystick there are two lights on the charger one red(power on) and the other yellow (turns green when fully charged). Plug it into the chair and if the light is green then you have fully charged the batteries. Now if you have the on-board charger the charger meter on the rear of the chair will resd zero when fully charged. Hope this helps ya
Aug 18, 2010 | Electric Jazzy 1115 Power Wheelchair
How do i know when my invacare pronto m5 is fully charged?
With an M51, a full charge will be indicated by all three joystick indicator lights lit- red yellow green. The green far right LED is the full charge light. Also the charger has indicator lights that go from red/yellow to full green at full charge. Hope this helps
Jul 11, 2010 | Invacare Pronto M51 Power Wheelchair
When charging the batteries, are there 2 lights that go on...1 red and 1 yellow?
on my m51 the lights on the charger are red and green the green is flashing what is this telling me.also should i have the controller on when i plu in the charger my chair i 6 years old battery replaced 2 years ago
Jun 18, 2010 | Invacare Pronto M51 Power Wheelchair
Lights on Rechargable Lantern.. Swissgear SG66301
I don't know how to solve your problem but, the three lights mean this:
Red LED light indicates the battery is being charged
Green LED light indicates that the battery is fully charged
Amber LED light incidates that the battery power level is low - the battery needs recharge.
Do not recharge you battery over 24 hours.
Nov 03, 2009 | Kitchen Appliances - Others
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
My motorola H700 keeps staying red when charging
Wait, how long have you waited for it to charge? It's supposed to stay red until over 80% charge, then switch to yellow. When it is fully charged, it goes to green. When you mean it stays red when plugged in, have you waited the 2 hours?
Jul 10, 2007 | Motorola Mobility H700 Wireless Headset
Jet 3 Ultra Power Chair Logo
363 people viewed this question
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent G
Vincent G
ray gallant
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
