BMW 1998 740 iL Logo
M
Magno Ramirez Posted on Jul 19, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
BMW 740li car won't start. Already changed fuel pump, relay, and fusses 57 and 17. Current doesn't seem to reach the fuel pump. What could possibly be the problem?
Dwayne L brown
Level 2:
Habit-Forming:
  • Expert 50 Answers
  • Posted on Jul 19, 2016
Dwayne L brown
Expert
Level 2:
Habit-Forming:
Answers
50
Questions
Helped
15001
Points
304
2answers
Where is the fuel pump relay located in this vehicle.
fuel pump fuse is fuse no35 30A
or fuse no 40 20A
fuel pump relay is incorperated in the fuse box which is located behind glovebox
1991 honda accord starts intermittently. When it doesn't the gas guage goes below E. Gets spark, no fuel. Already changed main relay.
Hey man if you already changed out the relay i would try changing your fuel pump and sending unit that should stop both of your problems.
2answers
Why won't my 1997 Saturn SL start?
you have spark at the plugs ..thats something
spray stay you mug
into the throttle body see if the motor will cough
tank needs draining and have fresh fuel
fuel pump has a filter and fuel relay
crack the fuel line connection to the rail to see if there is fuel reaching the rail and correct pressure
if sitting 6 years.. not being run regularly
do a compression test
lifters may be stuck
rings may have lost tension
1helpful
3answers
95 bmw 740 il
Probably not the filter, the Fuel Pump is located under the Back Seat.
Vehicle will not start at times.Isuspect a faulty fuel pump or fuel pump relay.
change the fuel filter this may be dirty .if it has done 130,000 miles change the pump
Tried to start my 1998 Gd. Cherokee Lmtd. but it seems doesn´t pump gas
Hi, you should start by checking all your fuses,if they are all good ,check fuel pump relay, if this is ok , check fuel filter, if filteris good ,you should run a fuel presure text, this will determine if your fuel pump is ok, good luck.......
3answers
1995 e34 520i won`t start
i would check the fuse for the fuel pump and the relay.
Top BMW Heating & Cooling Experts
Paul Carew
john h
Are you a BMW Heating and Cooling Expert? Answer questions, earn points and help others
