The speedometer works for about 10-15 minutes of riding then flutters and dies. This leads to the cruise control and self cancelling signals not working then stalling when coming to idle. Is the speed sensor under the starter??
Dan , VSS is under the starter in the back of transmission. may have to remove starter to get easy access. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to replace VSS vehichle speed sensor on 2007 FLHTCU Ultra classic...
2009 Harley FSXTC Speed sensor removal and replacement part
vss location Harley Davidson Forums
Harley Speed Sensor Fix My Hog
