How do I reset the weight on a weight watchers scale. Every time I step on the scale it reads 181.8. I know I have lost weight because my face is thinner & my clothing are much looser.
HELP PLEASE!!!!
It is possible to switch the weight measurement on a BlueTooth Weight Watchers scale, Model WW941R, from kilograms to pounds through the use of the Weight Watchers app. To do this, follow these steps:
Download and install the Weight Watchers app on your smartphone or tablet. Open the app and sign in to your Weight Watchers account. Tap on the menu icon in the top left corner of the app. Tap on "My Account" and then tap on "My Devices." Select your BlueTooth scale from the list of devices. Tap on "Device Settings" and then tap on "Units of Measurement." Select "Pounds" as the unit of measurement. As for the BT name, it is possible that the BlueTooth name of your scale is "WW941R." You can try searching for this name when pairing your scale with the Weight Watchers app or another BlueTooth device. If the name is not displayed or if you are unable to pair the scale, it is recommended to consult the user manual for your specific scale model or contact the manufacturer for further assistance.
I have a "Thinner" scale. You have to put a little weight on it to activate, it will show 8888. Don't step on, wait a few seconds and it will change to 0000, then step on.
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
