I have a Samsung Plasma PN64D7000 set that first have problems with HDMI inputs not switching to the correct port. Within a few days all HDMI ports stopped working except HDMI port 2. Using port 2 I still got a beautiful picture. I was about to purchase an HDMI switcher which I could just pull into Port 2 and plug all my devices into the HDMI hub/Switch --- then the problem got worse. HDMI 2 stopped working and the set stays on. It won't turn off with the remote or hitting the power button on the set. I've unplugged it for days at a time, when I plug it back in it powers on but the screen is saying No Input Signal. The only way to power off is to unplug the set. Any suggestions?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
