B
Bougatt Posted on Jul 16, 2016
How to reset sony PDW F355
I gave a trouble shoot on my cacorder PDW F355, i want to reset factory default
1 Related Answer
Anonymous
  • 368 Answers
  • Posted on Dec 01, 2012
SOURCE: SONY PDW-F355 with error code 02-F37
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
1helpful
What Drv Adj err in PDW-F800 sony
Firmware Update is needed.
FUNCTION IMPROVEMENTImprovement of Disc Servo firmware to correct "DRV ADJ err" or "DI read err" error message appearance. COMPATIBILITY INFORMATION
1.) If this model is used in combination with PDW-U1 or PDW-U2 ,upgrade XDCAM drive software to v2.3.2 or V3.1.1 or higher respectively.
2.) Windows & Mac FAM Drivers must be upgraded to V2.3.0 or higher beforehand
3.) XDCAM BROWSER must be upgraded to V1.3 beforehand.
4.) CONTENT BROWSER must be upgraded to V1.1 or above beforehand
5.) If PDW-F800, PDW-HD1500 or PDW-F1600 is used in combination with this model, it must first be upgraded to V1.71 or higher.
6.) HDCA-702 used with this model must be upgraded to V1.10 or higher.
CAUTION ABOUT UPDATE PROCEDURE
1.) Execute "All File Save" to Memory Stick before starting the upgrade,after the upgrade please execute "Factory Preset" followed by "All File Load" from MS.
2.) Be sure to use external DC Power,Battery not recommended.
3.) Implement software update without disc inserted.
4.) Set VDR power save switch to STBY position.
5.) Disconnect all I-Link and Audio cables.
6.) If the Power is turned OFF during the process,restoration of the software package will not be possible, be careful.
7.) Follow the installation instructions in the Release Notes.
https://pro.sony/qf_CA/product-resources/software-firmware/1237492951598
https://pro.sony/s3/cms-static-content/operation-manual/3297517131.pdf
Sony pdw-700 error 02-f37 Sony pdw-700 error 02-f37 How to fix it
There's a internal ND filter mechanism check around the optical block detecting that something is not working.
Send it over to a Sony Service to repair, there's nothing you can do about it.
Trouble shooting problems
To reset the surround mode and other settings to factory default, hold down the VIDEO 1 button while the system is turned on and then press the STANDBY/ON button. "CLEAR" appears in the front display and the system will enter the standby state.
SONY PDW-F355 error code 02 F 37
There was a firmware update (2.01) to correct this. May 14, 2012
Servo drive function is improved as follows.
The servo drive is now adjusted correctly, and the adjustment no longer results in offset values from characteristic variations in the alignment disc (PFD23A-RS).
Previously, when not adjusted correctly, inserted discs were not recognized, DRV ADJ Err (Error 6F-E00/6F-E80) appeared, and the unit stopped operating.
Pdw u1
This indicates the hard drive has errors from bad sectors to file corruption, the hardware should be tested, maybe possible to repair.
1helpful
Error 03-454 on pdw1500 deck
What is error03-354 on my Sony XDCAM PDW-F350L?
Thank you. HELP! email: [email protected]
Pre-shooting with sony dsc H2
There's a chance that the settings might have been changed.....Just try after resetting the camera to default factory settings.
We forgot the password
try this and see if it works for you please email me and let me know first To reset the print server using PS admin follow the steps given below: ----------------------------------------------------------------------------------- Step 1 Open the PS Admin software, select the print server you wish to reset to factory defaults, and then click Factory Reset. Step 2 Click Yes. Step 3 Once the reset procedure has been completed, Click OK. The device is now set to factory default settings. For D-Link's preferred Home Networking application please try http://www.networkmagic.com/nmlp/dlinksupport.php from Pure Networks. It simplifies Microsoft Networking and may allow you to trouble shoot your network on your own. like i sai dtry this and let me know thanks keith
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
