The B500 is compatible with SDHC and SDXC cards. That means you can use cards from 4GB all the way to the largest cards currently available. (at that time 128GB)
And is it less than 128GB?
Your Nikon Coolpix B500 Digital Camera is compatible with 16GB, 32GB, 64GB and 128GB SD, SDHC and SDXC memory cards.
Because that card is Waaaay beyond the specs! Did you read the manual??
The memory card (SD/SDHC) is
optional and not included in all
camera packaging. It needs to be
purchased separately. Please use an
original memory card which is Class
4 or higher and has a capacity of 4GB to 32GB.
Did you use the phone to format the card before transferring files onto it? Sometimes the phone has to format it in order to be able to read it. Keep in mind refomatting the card will erase all of the data on it so back it up before give this a shot. good luck!
Its a plug and play hardware that you can insert in usb socket of your computer... wait for your computer to read it and prompted you "your hardware is installed and ready to use" seen on the lower right portion of your monitor. Insert the memory card from your camera or phone on the usb all in one memory card. You can start browsing the files from your memory cards.
Hope it help.. Much appreciated if you could rate this help.. thanks
