It's getting gas just red spark and want crank
Hi Austin:
Counting on my fingers I make that over 25 years old, so the maintenance history and mileage become very relevant.
I'd be considering an ignition tune-up as an appropriate first step.
Changing spark plugs, plug lead harness (wires), rotor, cap, coil, Points & condenser (or solid state components.
Chances are it will show a remarkable improvement.
Red spark is very low voltage
possible coil failure or ignition control module failure
at 1991 I would think that it has electronic ignition and not points but not EFI but if it has points replace the condenser
I would consider a coil failure as closer to the problem
check the resistance reading or voltage of the 7.5 volt lead to the coil as if the resistance has gone high , the voltage to the coil could be too low to generate a quality spark
Testimonial: "It was running but it would spit and sputter unless you let it warm up a little then the service engine light would come on and it would run fine except try to stall in reverse then I was going down the road it made a back fire noise shut off and ain't started since"
ok -- lets sort this out. you say that it has spark but will not run, then you say that it is running and is allowed to warm up but plays up then backfires
--Is the vehicle efi controlled (ECM) because you mentioned service engine light and if it is,- why have you not had the fault codes read
everything about the low voltage is valid regardless, it is just the method of getting that spark varies between points,electronic ignition ignition control module and ECM
so in your next comment , state if it is EFI with injectors or carby, single coil or multi coil, distributor as the information you are providing is confusing
I have it says oxygen sensor but it doesn't have catalytic converter it has 1 ingector single coil distributor is new
replace the coil
Car cranks, has spark but will not ?
http://howtobyme.blogspot.com/2011/12/car-crankshas-spark-but-will-not-start.html
The spark plug firing order for car?
http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
How to Replace Spark Plugs?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
How to Perform a Basic Engine Tune Up-Spark Plug and Wire
Change
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up_01.html
Car has no spark?
http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
How does the spark plug wire go on the distributor cap in
1991 Mitsubishi Mighty?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
No spark on 2008 Chevy Avalanche?
http://schematicsdiagram.blogspot.in/2012/04/no-spark-on-2008-chevy-avalanche.html
1985 Pontiac sunbird?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wire-go-on.html
Ford Plug Wires Not Coming out?
http://whoisbyme.blogspot.in/2012/06/ford-plug-wires-not-coming-out.html
Ford explorer has no spark?
http://schematicsdiagram.blogspot.com/2011/12/ford-explorer-has-no-spark.html
Chevy impala spark plug firing order diagrams?
http://technoanswers.blogspot.in/2012/02/chevy-impala-spark-plug-firing-order.html
How to gap spark plug on Chevy Impala?
http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html
Spark plug Replacing for chevy impala?
http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
Chevy s-10 blazer 4.3l Spark Plug Firing Order?
http://howtobyme.blogspot.com/2011/12/chevy-s-10-blazer-43l-spark-plug-firing.html
1982 dodge rampage Spark plugs Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/1982-dodge-rampage-spark-plug-firing.html
2006 Suzuki Forenza Spark plug Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
1983 Ford Ranger Spark plug firing order?
http://schematicsdiagram.blogspot.com/2011/12/1983-ford-ranger-spark-plug-firing.html
Firing Order for 1991 Lexus ES 250?
http://schematicsdiagram.blogspot.com/2011/12/firing-order-for-1991-lexus-es-250.html
Firing order for 1992 Chevrolet 5.0 engine?
http://schematicsdiagram.blogspot.com/2011/12/firing-order-for-1992-chevrolet-50.html
How to identify number one spark plug on the distributor
cap?
http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
How to remove rear spark plugs on 1991 Buick Regal?
http://howtobyme.blogspot.in/2012/02/how-to-remove-rear-spark-plugs-on-1991.html
These details will help.
Thanks.
