The yellow wire on my jensen vm9410 came unpluged fom the back of radio and there are two possable spots they r on the end side by side could u tell me which hole it goes in to prevent blowing it up?
Sure. The wire u are looking 4 is located in the bottom right side of the plug. Under the Bat (Red) and Ground (Black). On the last hole on the harness. Had same problem. Hope this helps you.
the yellow wire needs to goto a permanant power source such as the battery or a wire that stays live, the ground wire needs to goto another ground wire, or to a part of the car frame.
easiest thing first. check the fuse on the hot wire on the radio harness. next, check to ensure the hot wire is to battery power, and the acc (likely yellow or orange) is attached to a wire that turns on with the ignition. next, check to ensure good ground. all this should take less than 10 minutes.
wire the parking break wire from the deck to the ground and it will work like a charm, until your crappy vm9410 all of sudden won't turn on any more :( It seems no one has a solution for that PROBLEM!!
Make sure that you have a good ground, Connect the orange wire and red wire are both connected to a reliable ignition wire and that the yellow wire is connected to a straight battery source. And that your fuse, if any, is tight and good. If this does not help, there may be internal problem of many sorts.
My only suggestion as last desperation, take your dvd player out of the vehicle. Open your hood, Take the yellow, red, and orange wire, tie them together and hook it to the positive post, and black to the negative. If your dvd player comes on like it should, Then it prolly a problem in your cars computer. Some newer cars automatially disable their radios when an alarm goes off, for theft reasons.
