My display function has failed and I cannot see to reset programmes
Follow the steps below in the order presented: Perform a power reset on the camera. Performing a power reset on the digital camera will normally correct issues such as the camera locking up or not turning off. When the power reset is performed properly, the camera will prompt you to update the camera’s date and time. This is an indication that the memory has been cleared and no further reset time is required. The power reset procedure must only be performed on a camera that has been running on battery power. If an AC power adapter is being used, the power reset procedure does not apply. This is due to the fact that the internal capacitor is fully charged. To execute a camera power reset, perform the following steps: Turn off the Digital Camera. Remove the Compact Flash Card or Secure Digital Card, if one is being used. Turn on the Digital Camera. CAUTION: To avoid damaging the camera, ensure the shutter button is not pressed during the following steps. Turn on Live View on the rear LCD. CAUTION: Care should be used when performing Step 5 to ensure that the camera is not dropped. Open the battery door and remove the batteries with the camera turned on. Re-insert the batteries after five minutes have elapsed. Turn on the camera. The camera should request an update for date and time (with the exception of the HP Photosmart 120 and 912 series cameras). Format the memory card. Navigate to the delete menu which varies with each camera, and format the internal memory and/or the memory card. CAUTION: Reformatting the memory card erases all of the files that are stored in the card. All photos, scripts, and miscellaneous files are deleted permanently. To preserve the existing images, use a spare card or a card that is already formatted.
SOURCE: Display clock failure so no main oven
check you have power to clock and if not, check wiring back to find out why not. to get oven working, you can bypass the clock by joining the two wires to the clock relay. these clocks are remarkably expensive
SOURCE: Sharp 1505 Microwave Display Failure
There are two options for this model:
You can order our exclusive modified control unit (CU150) with our proprietary upgrades
for $95, then if you return your defective control unit in repairable,
good cosmetic condition, we'll give you a core refund of $40. Details are here.
- Or we can repair your existing control unit for $39.95 in about a week with a one year guarantee.
We have
the service manual for this model and have uploaded it to our
site here to help you.
Repair service details are here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: machine wont work and flashes f12 on function display
f12 is a communication error between the circuit boards. engineer job. if the machine is less than 5 years old the parts are free but the callout +repair's about £100 from hotpoint.
