Question about Korg Music
I have korg ax3000g. my quastion is how to load patches in my procces in windows
My korg N364 is out of tune. how do i fix it?
hello sir,
THIS IS SOFT RESET; FACTORY MUTE PARAMETERS WILL BE LOADED INTO ... ART, MULTIVERB LTX, No factory reset, remove battery for more than 5 hours. .... KORG, N364, HOLD ENTER AND 7, THEN POWER ON. KORG .... ROLAND, D-550, TUNE/FUNCTION AND MIDI DATA INIT: HOLD PATCH BANK 2,
thanks from: SHAAD GONDEKAR
Feb 21, 2017 | Korg Music
I have a korg n1 and when I turn it on the display screen comes on but no words show up on it I was wondering how to fix it
It sounds like your ROM battery, which the ROM contains and stores the patches for the keyboard, has gone completely dead and your keyboard is dead in the water. However, if you can get a MIDI to USB converter and get the battery changed, then you can reload the patches back onto the keyboard.
I have worked on a Korg M1 Workstation and have had to replace the battery(CR2032) and then had to run a program called "MIDI-OX" which also gave me access to the patches needed in order to restore the keyboard to factory patch settings.
http://www.midiox.com/
Take a look at this AFTER you have gotten the battery replaced. I will tell you that replacing most batteries is a very intricate job as, the bottom of the keyboard has to be removed, as well as a lot of the internal boards. I had to draw a diagram and mark certain pieces so I would know where they went and in what order they have to be re-attached. My advice is take it to someone who works on electronics unless you want to DIY (not recommended) to get the battery replaced.
Hope this helps.
Apr 05, 2016 | Korg Music
My synth wont load when I power it on. can anyone help?
I suggest a hard reboot / initialize. Istructions are in your manual or on the Korg website
Jun 09, 2015 | Korg Pa800 Synthesizer
How factory setting korg Pa50 sd
Please see "Loading Korg Pa50SD's Operating System" below for
instructions on how to load the operating system.
Oct 04, 2013 | Korg Pa50 Professional Arranger Keyboard...
Como resetear korg..
para resetear el pa50sd
Sep 12, 2013 | Korg Pa50 Professional Arranger Keyboard...
How to turn on en off the moulation of a korg x5d
For Combi/Multi patches you can disable control changes for each sound under EDIT 6D but this also switches off other control change instructions (pan, expression, pedal etc.).
Somewhere under GLOBAL settings you should be able to find the modulation wheel Depth setting and set it to 0 which should stop your mod wheel from working but you could achieve the same effect by just keeping the mod wheel pulled all the way down.
Jul 28, 2011 | Korg X5d
My korg x5 keyboard only turns on but nothing comes out of the display.nothing is loaded and no characters displayed.
Download the owners manual from here and try doing a reset to factory settings
http://www.korguksupport.co.uk/page.cfm?pageid=391#Owners Manuals
Feb 18, 2011 | Korg X5d
I am trying to load the new OS for the triton studio. My studio says i need sysyem 1 disk. I don,t have it. Solutions?
They need to be downloaded from korg.com. You need to have a floppy disk drive to load them unfortunately.
Jul 14, 2009 | Korg Music
Music Logo
122 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Experi
Level 1 Expert
David Gust
Are you a Korg Music Expert? Answer questions, earn points and help others
