Washing Machines Logo
l
lucy pickett Posted on Jul 12, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag top loading washer water starts to fill then turns off
The water turns on then about 10 seconds later stops
Nater13
Level 3:
Master:
  • Maytag Master 610 Answers
  • Posted on Jul 12, 2016
Nater13
Maytag Master
Level 3:
Master:
Answers
610
Questions
0
Helped
242510
Points
2229
What is the model number?
Testimonial: "MTW5870TW0"
  • Nater13 Jul 12, 2016
    http://www.repairclinic.com/PartDetail/M...
    Most problems of this type on this model revolve around this part: WP8578335. If it doesn't sense the water as being the correct temp it can interfere- put the temp selector to COLD and see if it will fill all the way and begin washing...
Washer fills for seven seconds then stops.
This is most likely an issue with the inlet pump. You can check for a clog or blockage in the pump by opening up the washer and checking the hoses and connections. If everything looks clear, then you may need to replace the pump.
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
1helpful
Maytag top loadind washer. Won't stop filling up.
Make sure your drain hose to the drain pipe is higher than the water in the tub if not it will keep running and going out the drain.
Also try taking the hose off the level switch and blow in it to be sure it's not stoped up. If is it won't let the level sw cut off. air should go through it. Good luck
When you unpluged the power and it ddn't keep runing the water valve should be ok.
2answers
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
1helpful
Maytag top load washer starts to fill then stops
I have a maytag washer and it starts up and starts going then it stop and if i push start again it will go but it keeps doing it what could it be
Neptune MAH3000AWW will start to fill when start is pressed, but stops seconds later
either a faulty pressure switch / pot or faulty controller - either way you will need to call someone in.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
