SOURCE: Transfer the Call
how do i put the answer phone back onto the phone so when ppl riing the office the answer phone comes on to tell them what to ring when the office is empty
SOURCE: number of rings before going to voicemail on KX-T7630
Press the FWD/DND button, then scroll through the menu button until the screen shows "FWD No Answer time". Then use the number key pad to change from 000 seconds to 010 seconds (or longer if required). Then exit out of the menu.
SOURCE: Instruction on how to divert incoming calls to a mobile.
hey c'mon please let the receptionist go after you have finished , why you want her with you?
SOURCE: Changing Panasonic KX- T7630 Business Phone Answering Message
You don't "lose" the manual, it comes on a CD. The Panasonic system probably has a TVA voice mail system and it requires you to change the Auto Attendant greeting from the message manager's mailbox. If you don't have the passwords for mailbox 998 and 999, you need to contact someone who has them and a layout of the system.
Your Panasonic technician can guide you through the process.
Carl
SOURCE: How do i divert all calls from the kx-t7630 to a
You must subscribe to you Landline Supplyer for 'Call Divert Services' If Say you already Subscribe to BT.
The Proccess is access line... the on the Keypay dial... *21* (then The No; to be Diverted To) then confirm by pressing the # Key. Wait and the No; will be repeated to you.
To take off call divert access line dial #21#
When 'Call Divert' is set you will receive broken dial tone. through the Handset.
(Like a Siren)
