First - the air pressure has to be high enough - check the regulator on the tank to make sure it is delivering in excess of 60-70 psi (which I am sure you have already done).
If you have dry fired these guns (i.e. shot them off with no nails in them while you were lubricating them maybe) the mechanism inside could be damaged. I had that happen to one of my nailers (same brand). That was when I learned not to dry fire them...
Since both of them are not working though I would be more inclined to look at the air supply first.
Have you been lubricating it regularly with nail gun oil. We use
framing nailers every day at the commercial tree farm I work at and one
of the operating instruction is to put 6 to 8 drops of oil in the air
hose connection on the nailer before every use. I suspect the O ring on
the piston is worn out/
Hope this helps Good luck Loringh PS Please leave a rating if appropriate Thks
if its debris. can i clear it out. or buy a new trigger assy
