T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts.
Testimonial: "Sorry Knight changed board still doing same thing. I did notice the motherboard very hot, you think this could be it? Power supply maybe?"
SOURCE: Buzzing sound on Vizio Plasma TV
hums when certain appliaces are used washer microwave skill saws
SOURCE: Power Light comes on but no picture or sound.
for your VP50, it could just be simple as a power supply but it could also means more. Do you have the amber LED light when off and green when on? if so, try the main board first. If that doesn't resolve the problem, then change the sustainer boards.
SOURCE: i have picture but no sound on my 42 inch vizio
If you received a remanufactured board it might be defective,Or did you forget to hook back up the speakers? Sounds dumb but happens alot. Speaker wires get in the way,we disconnect them to look at a board or replace one.Often gets over looked.But I have received several defective boards.Hope this helps. Toddthetvmd
SOURCE: vizio vw37l, tv comes on, i got sound but no
Hello
The T'con board [Timing Control Board] of your TV has damaged.
The board will look like this. Will be in a shelded case which you can open it by unscrewing it, and can take out the board. Replacing it is a semi-skilled job indeed. You can buy this board from most of the electronic spare part shops at your town, or from the authorised service center for Vizio at your town. Never use a refurbished bord in place, as it may make damage to other boards. If you want its service manual, not user manual, you have to buy one amoung my pro service from Fixya. I can't send it to you directly as it is against our expert terms. If you wish to get the service manaul, get me either by Fixya Pro services, or just type my nickname "gopakumarg43" in Google search box; where you can see my services, and get me. OK.
