Probably needs at least one new rubber seal, you'd probably contact your supplier.
Various spare parts are shown in this manual (attached):
Hi Roger:
Spray mode creates more pressure in the internals, which will make any poor fit or bad seal leak.
The first thing I would do would be to check all coupling points to make sure they are tight.
I'd dry it completely, and then turn it on in spray mode for just a second, then use tissue to dab at the leak location to determine the exact point where it is leaking.
Once you've isolated the leak, fixing it is usually very straightforward.
Cheers
