Dryers Logo
Maggie Neasdon Posted on Jul 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There's a wet patch on the floor when I use the tumble drier
Steven Clarke
Level 2:
Sergeant:
  • Expert 222 Answers
  • Posted on Jul 24, 2016
Steven Clarke
Expert
Level 2:
Sergeant:
Answers
222
Questions
0
Helped
141485
Points
567
4 Related Answers
Anonymous
  • Posted on Oct 21, 2009
SOURCE: Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Anonymous
  • 70 Answers
  • Posted on Jun 23, 2010
SOURCE: Simpson sirocco clothes drier tumbles ok, but heater not working
Bad heating coils, or bad ignitor if gas.
Anonymous
  • 1194 Answers
  • Posted on Jul 05, 2010
SOURCE: Drier does not tumble but it still heats.
Sound like the belt being broken or slipping badly, burn out motor, or worn support parts.
  • Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it.
  • You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it.
  • Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
I hope this will solve you problem
Good luck and have a nice day
Rating the solution is highly appreciated.
gwyz73
Gregg
  • 362 Answers
  • Posted on May 19, 2015
SOURCE: TUMBLE DRIER STOPPED HEATING
Gas dryer?
If so, probably bad gas solenoid valves. They can safely be replaced without fear of releasing gas. Two phillips screws, two pull off wire plugs. That's it. Cost about $30 bucks depending on where you buy them. They are a universal part and will fit 99.9% of machines.
www.repairclinic.com
Best of luck...
2answers
My Candy 7.5kg 1400 AAA washer/drier. How do I clean fluff which may gather from the drier of my machine.
It doesn't generate fluff, it uses evaporation to dry the clothes.
If it did, that instruction would be in your user manual.
Gas dryer?
Best of luck...
May 18, 2015 • Dryers
Hooverlightflashing
A tumble drier should only be used to dry clothes that have been through a hydro extractor (spin drier) first. They are not designed to put wet washing in. Dripping wet washing must first be wrung out or else the excess water will run out the bottom. If it is a washer/extractor, look for leaking pipes or door gasket.
Nov 25, 2013 • Dryers
6helpful
My hotpoint tumble dryer plug is very hot and making my socket hot to is it a fault with my dryer as scared incase it causes a fire .It is 2 years old.
It is normal for a plug to get slightly hot, but it is more likely to be a problem with the plug or the socket if it is getting excessively hot, and less likely to be a problem with the drier.
Firstly inspect the plug pins, are they discoloured? If so have the plug replaced.(You can cut the moulded plug off and fit a quality plug)
Try a different socket if you can.
I assume the drier is working normally, but you should not put excessively wet loads in the drier as it will be on for too long. Make sure the clothes are as dry as possible that will reduce the time the drier is on.
regards
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
TUMBLE DRIER-INDESIT IS70C
hi did u check the hoses from the pump and check the pump for any obstructions.
1helpful
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
White knight 767 tumble drier
If the rug was very heavy you could have burnt up the motor. If it will restart after it cools off, replace the motor and clean out the vent system.
Good luck.
Dec 08, 2007 • Dryers
Top Dryers Experts
john h
