Possible low freon are the coils sweating or freezing up also is fan running
Seems low refrigerant issue need to refill refrigerant
Is the compressor running. If you are able, check capacitor, check amp draws
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
SOURCE: ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
SOURCE: NOT BLOWING COLD AIR
Compressor is not working. either a relay or the compressor is malfunctioning. You need a technician to check it out.
SOURCE: carrier air-v AC is not blowing cold air
There could be a freon leak, or just low freon levels. If this is the case, you have to call a certified a/c technician to recharge your system.
