Bryan Theutama Posted on Jul 09, 2016
Why my sony digital photo printer DPP-FP60 only print half oh the pictures
3 Related Answers
Anonymous
  • Posted on Feb 07, 2009
SOURCE: Cannot print from PC with Vista to Sony DPP-FP30
I downloaded the appropriate driver for Vista windows from a website which has hundreds of different drivers and it works a treat now.
Anonymous
  • Posted on Apr 01, 2010
SOURCE: Cannot find the driver for mac for sony DPP-FP60
Export your photo from iphoto to a usb stick. Then stick that into the printer´s usb port. Use the menu of the printer to make any last corrections (size, brightness, borders etc). Works with both RAW and JPEG. Good luck. /Anders
Lance Hill
  • 1739 Answers
  • Posted on Jan 16, 2011
SOURCE: i need a printer installer
Go to: http://esupport.sony.com/US/perl/swu-list.pl?mdl=DPPEX7
Select your operating system from the drop-down menu.
If a driver and /or software is available a further menu will be displayed.
Why does printer only print half of the picture
Your paper size may be samller then the size of the image you are printing. Try changing the size of the image or size of paper to match.
Why is the sony dpp-fp90 digital photo printer only printing half the picture?
Are you using a large image size, try smaller size file..Its a data processing problem. clear the memory of the printer.If persists it could be a lose data cable in the printer if the printer has had a knock
It only prints a 6x1"
Sony printers are masterpeices when it comes to digital printing as they produce wonderful quality images.
If you got a new printer and it does the same thing this indicates that the problem iis emanating from the software with which you use in editing the pictures before sending the print command. Somewhere along the line some adjustment must have been made to the software relating to the alignment of the picture on the printer. Once this adjustment is corrected your printer will print fine.
Printers are devices which prints what command was sent to them and do not have any intelligence to act or edit documents on their own accord.
Hope this solution has been helpful?
Happy new year
3helpful
2answers
Need driver update for Windows 7 - 64 bit. Is there one?
The Sony Support site does not list a driver for either Vista or Windows 7 (neither 32 bit nor 64 bit). If you have Win7 Pro or Ultimate, you can install the XP mode and load the driver for this printer on to that virtual machine.
I hope this helps.
4helpful
2answers
1helpful
Sony Printer DPP-fp90
You may use your memory stick option to print. I means you shall copy your pictures to a memory stick card. Insert in into the printer. And print directly without your MAC. I use Sony DPP-FP70. It works.
TROUBLE PRINTING
These are following cases for this symptom.
If the access indicator flashes in green:
The data size of the image is large and it takes longer to process it for printing. Printing will start as soon as the data processing finishes.
If the paper error indicator flashes on the LCD:
The paper is jammed. Turn off the printer and turn it on again, take out the paper tray, and then remove the jammed paper from the paper outlet. If you cannot remove the jammed paper, consult with your Sony dealer or service facility.
If no indicator is lit or flashing:
The thermal head may be overheated. Leave the printer until the head cools down and the printer resumes printing.
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
