Ron, F60 is a general error code usually related to a failure on the video processing board. You could fix this by just replacing that board. Try to place it in standby mode first by unplugging it, wait a couple of minutes and then plug it back in. When the 000000's starts, hold down the power button for 15-20seconds. The unit should then be in standby mode. From this mode try to start it normally using the power button and see if it cleared the error. You could also try a complete reset by powering the unit off and press and hold the "Stop" and "Channel Up" buttons at the same time for a few seconds while powering the unit up. Hope this helps, good luck.
SOURCE: Panasonic DMR-ES40V, error codesF60 & U99...
Same problem. Contacted Panasonic. Technician indicated that there is a problem between the CPU and the timer. The unit is three years old and out of warranty, so he offered Panasonic's service at $120 for labor plus any parts.
So I gave it one more try. I pressed and held the REC on the Power button for about 10 seconds, which reset the unit. Then I was able to play a DVD and eject it.
Hope this helps with your unit.
SOURCE: F60 Error message on DMR-ES40V unit
Unplug the unit.
Plug back in and wait till you see 000000.
Press and hold the power button in at least ten seconds or until the clock shows up.
This worked to fix mine.
SOURCE: DMR-es40v f60 error
Problem for Panasonic DMR-ES40V DVD-Video Recorder with Built-in... Maching displays F60 as soon as it's turned on and
SOURCE: F60 ERROR CODE ON PANASONIC DMR-ES40V
Unplug the unit for 24-hours. I know, it should not take that long, but in this case I tried shorter periods WITHOUT success!
Just before plugging in unit depress and hold POWER button. You are supposed to hold it for 30-seconds after plugging in, but in my case I did it for 60-seconds. This results in a MASTER RESET that clears all errors, resets interlocks, etc. I could not get past a DVD failure problem, but when I discovered this process everything worked fine!!
Good luck! Hope it works for you too.
SOURCE: Panasonic dmr es40v came with wrong region code
Hi, kindly get the code here :
www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__5rtg6
