Sources of PCBs in Natural Gas Sector: PCBs are most likely to be found in equipment associated with the processing of the natural gas (
Phase 3). For example, old transformers and capacitors, other electrical equipment including voltage regulators, switches, reclosers, bushings, and electromagnets, oil used in motors and hydraulic systems at
gas processing plants. In addition, major interstate natural gas pipelines transport natural gas from production areas to local distribution companies (LDCs) that distribute the natural gas to industrial and urban customers. PCBs were used in turbine and air compressors as a hydraulic/lubricant and a plug valve sealant by some large interstate natural gas transmission pipeline companies and by some smaller LDCs. Some interstate pipeline companies may also have had PCB transformers and/or PCB capacitors at large compressor stations and/or maintenance facilities. Similarly,
old gathering lines, which move gas from the well/well field to the gas processing plants, might also have compression stations that contain legacy PCBs.
