HAD THE SAME PROBLEM MINE FIX WAS A DOUBLE STACKED DIODE
What are you pluging into the generator??? If the the item/s are drawing more amps or watts, than the 6500 will handel, EX: 6500+or++ or if you add something while it is running, ka pow! Please let me know specifically what you have pluged into it, the fuse only blows if you are overloading it! Check the amp or watt draw of what you are pluging into it to see if the generator can handle it. If you overload the generator enought times you can burn the windings and than it gets costly. Talk to your local shop about what it can handle.
