There is no backlight , the sound is okay
If this is a DLP TV you will need s new DLP bulb.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Testimonial: "thanks for the info but i did not find the model i'm looking for"
Just search for "Samsung LCD TV". Blinking codes to Samsung TVs are the similar for all models. The site I've linked here has nearly 5000 posts related to TVs and other devices. All of it are not categorized. The author of that site have posted it; as when he get the data and authorization to present them before the public; from the relevant companies; I assume.
It really help me much nowadays; I should say.
