To use the worry-free backup battery, get a 9V battery. Then look for the battery compartment on the bottom of the unit. Press the tab with your thumb and then lift the cover out and away. Plug in the battery and then replace the cover.
Press Wake Time once and use the forward/reverse buttons to set the alarm time. Then press Wake Mode repeatedly to toggle between the options of wake to radio, wake to CD, or wake to alarm. (Note the radio must be tuned to your desired station and a CD needs to be in the player for these to work).
The Smart Snooze means that pressing Snooze, forward, reverse, play or stop will turn off the alarm temporarily. (Pressing Off will prevent the alarm from sounding again today.)
Amazing allysen takes two sets of batteries. When you open up her back you will see where you replace 4 AA batteries. If you open up the littel doors UNDER the AA's there is a space for 3 AAA's. That might be a solution.
I can tell you this if you find the switch that is on Amanda back this turns her on. You must be in a quiet room. You have to touch her one of her hands to make her speak. The right one should do the trick. This link has a lady talking about the doll and going through instructions setting up the doll. It seems like a pretty cool doll. http://www.archive.org/download/LarrySkutchanbct266AmazingAmandaDemo/bct266AmazingAmandaDemo.mp3
The instruction manual will not help you, because it doesn't address this problem head on. You're having this problem because the time changed, and the clock has an automatic setting. As long as the batteries are in the clock and it's plugged up, it automatically computes the time. I just discovered the solution. Unplug the clock, take out the batteries and WAIT about an hour. Plug it back up, and the time will flash, allowing you to change the time. You do this with the button on the top back which says wake up 1 and wake up 2. Push that button all the way to the right to the setting that looks like a little clock, then press the forward button on the top of the clock to set the correct time. Then put your batteries in and you're good to go! (til the time changes again:) Good luck!
