Information for advanced users. The absence of an image in the presence of a signal is often caused by a malfunction of the display backlight. Moreover, the problem can be both inside the LCD panel (matrix), for example, a malfunction of the LEDs( LED), and outside in their power source - the LED driver. Without the backlight, you can sometimes see a barely noticeable image with a certain successful hit of external lighting on the screen.
Dashboard backlight works together with the tail light. Both the headlight and tail light is controlled by relays. Check the engine bay fusebox. Look at the inside of the fusebox cover and you can see the 'location map'of relays and fuses. Theheadlight and tail light relays sits side-by-side. Change both and check for blown hedlight fuses..
Normally all the backlight inverters have fuse. It would be an SMd type.
Of you wish to get some more details check the link below http://electro-medical.blogspot.com/
Back-light inverter board will have a fuse. Refer its circuit diagram to locate it. If it should blow up, there will be sufficient reason. Some short circuited components/s. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Circuit diagrams of many popular brand TVs and other devices are given.
Get free help, tips & support from top experts on jvc tv backlight related issues. ...JVC LT-40SX6AT flat screen. Was watching TV ... ...jvc logo, has sound but nopicture Backlight is defective. I suggest ... Question about LT-42E910 42" LCD TV.
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD ... LNT KDL Sanyo ln FLATSCREEN TV REPAIR FLAT SCREEN FIX - Hear Clicking .... i have a JVC LT42E910 WITH a cracked screen. there are all these color .... Vizio LCD Powers on with backlight, Wont power off, No video ...
Hello, This problem is caused by a bad backlight power supply. Check out this page on our web site: www.ccl-la.com/capacitors.htm If you can solder then you should be able to do the repair yourself.This page gives pictures and parts information. You will need to open your monitor and replace the parts call capacitors that are damaged as directed on the page. If you don't want to do the repair we do offer a repair service for $40 plus shipping.
I hope this helps, if so please rate our solution.
Have you asked proton about the bulb or inverter or power supply. Proton is going to be the only place to get them. Soory to have to tell you but proton doesnt have good customer service.
