Olympus WS-100 Digital Voice Recorder Logo
Posted on Jul 05, 2016
To reformat my recorder
What kind of details?
Anya Rampersad
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 18, 2016
Anya Rampersad
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
915
Points
There is a way to format this device. If you press the menu/folder button a couple of times, you should see a blinking message that says "FORMAT" with a "no" centered above it. If you press the "forward" button, you will change the "no" to a "yes" and you'll have to "play" to change the option to "yes" which will reformat the unit.
Good luck!! This worked for me!
I forgot my Acer Aspire SA80 system login password. How do I crack it? Do I need to reformat? IF yes, kindly guide me how to reformat my system
There is no need to reformat your system and loose all of your data. Please post me back what operating system do you use in order to reply with details. Also clarify me if you have a clean installation cd/dvd (no factory recovery or restoration) of your op. system in order to get you the right details.
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
After transferring recording to computer the voice recorder remained in the pc mode and i have been unable to get it to return t the recording mode the recorder is too good to throw away please help...
If you have tried removing and re-installing batteries and that didnt work you maybe should try reformatting...this will erase all files on handheld tho'...instructions for reformatting are in your operators manual or you can download a manual from www.olympusamerica.com
POCKETRAK 2G Pocket Stereo Recorder POCKETRAK 2G (2048 MB 45 Hours) Handheld Digital Voice Recorder: When loading audio files from my recorder the comp...
Try reformatting the yamaha 2G Pocketrak using the setting under Common. THe online manual mentions that if one uses the PCM setting for a lot of recording, it's a good idea to reformat more often.
3answers
Downloading music from my computer,deleting music
There are lots of methods. You can resort to online music download website, chrome extension, or music download software. Follow below steps, to know the detailed information. Leawo Music Recorder is a super recording software to help you record various kinds of music from multiple sources like online music like YouTube, computer audio, and built-in input audio. The recorded music files will be saved into an output format of MP3 or WAV.
1. Run Music Recorder on your computer and enter the recording interface. Audio source should set firstly before music recording. In order to record the music from YouTube, we should choose the option "Record Computer Audio".
2. Click the red button "Start" to make Leawo Music Recorder begin to work. Then play the music on YouTube. You should note that the music recorder should work prior to playing YouTube music.
If you want to decide the start and duration time of the recorded music, just click the icon button "Task Scheduler" then you can finish this customized setting as per your requirement.
After the music has been recorded from YouTube, you can use Leawo iTransfer to move the recorded music from computer to your iPod
Leawo iTransfer is a professional transfer program for transferring files between iOS devices, iTunes and computer. Various kinds of files are supported by this software such as music, apps and photos, etc.
1. Run Leawo iTranfer after you have downloaded the music on your computer. Connect your iPod with your computer via USB cable. The library of your iPod will be detected automatically and shown in the left sidebar of the window.
2. Import files to the software from computer in the following four-way:
I. Drag and drop the music files into iTransfer directly.
II. Click the button "Add" on the upper part which is beside the left sidebar.
III. Click the button File > Add > Add File/Add Folder on the top right corner of the window.
IV. Right click on the library and select Add File or Add Folder.
3. A pop-up dialog will be shown once you finish adding files and press the "Transfer" button. The name and the quantity of the transferred files will be demonstrated to let you know the transferring percentage. Remember not to disconnect your Apple device to your computer until the transferring is completed.
music-recorder-recording-t-ptaos1411zhprwnu0jdtasew-5-0_1.jpg For more details, check: How to Download Music from Your Computer to iPod
21helpful
5answers
Sony ICD-UX71F memory problems
You need to have it connected to your Mac and then empty your Trash (on the Mac) to clear the memory on the dictaphone.
1helpful
After I reformat my LG HDD video recorder to give me more space, it only clears a tiny portion. How do I clear the whole recorder? I am going to HDD format, and reformatting. Thanks
Do you mean it always shows 10Gb less space than the capacity of the drive. ie only shows 150Gb but you have a 160Gb drive? The reason for this is that it has 10Gb reserved for the buffer of the pause/rewind live TV.
Cheers,
Keith
1helpful
Need to know how to Manually reset RP5120-A
Plug in your recorder using the USB cable. Copy any of the files you see to your PC. Then reformat the drive. I don't have the exact details for doing this under windows but I fixed the problem this way.
65helpful
3answers
Sony ICD-UX70/UX80 digital recorder...memory full problem
I solved the problem by connecting my Sony IC Recorder to the USB port on my McBook Pro computer and then emptying the trash can on the Mac computer. Visually (flashing red indicator light) and audibly (the recorder's sound that indicates something being erased), it was clear that mp3 files were finally, really being erased on the Sony recorder even though the recorder's own screen display had previously shown only empty folders and no files. Dragging files to the trash can doesn't really erase them unless you also empty the trash. All dragging to the trash can does is somehow mark the files in a way that, unfortunately, makes them invisible to Sony's file detection system.
Chuck in Omaha
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
