SOURCE: Polaroid FLM-2601 flat screen
It has a protective outer screen and depending on the depth of the scratch you might be able to restore it. You'll need to look on-line at a few aircraft site for a kit that is meant to polish scratches from the plexi in an aircraft windshield. There is a company in Oregon http://www.chiefaircraft.com/airsec/Aircraft/Windshields/ScratchRemoval.html
that sells the kit for 34.95....
It is time consuming but I have restored many this way!
Bill
SOURCE: Repairing screen on a flat screen tv.
the screen alone is gonna be expensive for those tvs your best bet is to buy a whole new tv because to replace it is gonna cost the same for a new tv unless their is a warranty
SOURCE: Scratch marks on the tv screen.
you really cant, if it is still under warranty and they will cover it (make sure first by calling) then send it in. otherwise you will have to just deal with it, sorry.
SOURCE: 42" LCD TV leaves marks on screen following using
This is a defective LCD display panel. It will cost as much as a new set unless your still within the 1 year warranty. As far as cleaning the screen, you can use an old t-shirt by spraying a little windex on the shirt and wiping gently up and down or left to right but never in a circular pattern. I found it best to do this after the set has been on for 15 minutes to warm up the surface then shut the set off and give a clean.
