I had a breaker trip in my fuse box of my home and when I clicked it bacl on it is only giving power to half of what it supplies. I'vve tested it and it is getting full power and putting out full power but not everything it supplies is working. Why and how do I fix it and where do I start? This is a single pole dual switch breaker and the top switch is the one that tripped. It powers my back bedroom, Bathroom, a switch in my hall and 2 outlets on that same wall, a whole wall in my other bedroom and 2 switches in the bedroom also and then another wall in my living room which is right on the other side of my bedroom wall. Where do I start to test and how do I fix it? I have taken every outlet and switch out and checked to make sure that all wires are tight and they are. No loose or broken wires anywhere. Please help !
I strongly recommend that you get in an electrician to investigate the problem
from your description of the amount of power required from your circuit breaker I would consider that there are to power wires from the back of that unit
one circuit to run half the points and another wire to run the rest
If only 1/2 are working, I am thinking that one of the wires at the back of the breakers is loose or come undone/broken and that will require the services of an electrician
To further explain this line of thought, each circuit in a house is designed to carry a maxim of 10 amp total (wire current capacity) so that with all outlets in operation the maximum current is 10 amps
if the required current allowed exceeds that the electricians break the numbers up so that a second circuit is employed again up to 10 amps max
if again there was a requirement that exceeded the 20 amps ( circuit breaker amp) a second circuit breaker would be installed and a 3rd circuit and so on
Testimonial: "This is the first time that the breaker has ever tripped. I have the same things plugged in the same place that they have been for the last 3 years. Nothing has changed. I replaced the breaker and made sure that all wires are tightened and tight. I then tested both sides of the breaker and both sides are putting out power. What you already told me I have already done and I had an electrician tell me where to start and that is what he would do if he came out. He is a friend and has his electricians license and has had it for 27 years now so I figure that he knows what he Is talking about. I cannot call him all the time because he does work and is on call 24/7 so that is why I am reaching out on here."
I use a tool called a PlugGrip... Model 00002
It will test both outlets at the same time.
the tool has 2 Neon lamps to validate if both outlets are energized.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
U have to test power on these devices u could have pla loose connection when it comes to trouble shooting the device might be causing not to send power to next device. Like a plug that went bad if the wires aren't pig tailed together it wouldn't send power to the next box. I'd go in get a plug tester make sure there's no open grounds or neutrals. And take the device out and wire nut the black wires together on the plugs aand white wires to bypass any problematic device
It works just like a normal circuit breaker with one additional function. A shunt-trip breaker also has a built-in magnetic coil that can be energized externally to trip the breaker.
So what is wired to the shunt that is not letting the breaker reset?
Read more: http://wiki.answers.com/Q/How_does_a_shunt_trip_breaker_work#ixzz1EXNCP5r0
