Hello Ursella Thompson,
Absolutely no information came through with your question about... Room air-conditioners (make/model/size)...
Which is actually okay because those calculations...
immediately become quite complex MORE BECAUSE OF THE ROOMS (& your climate) than the air conditioner.
The size of the room... height... INSULATION.number of windows (fenestration) & doors (their relative insulation, composition & size... drapes, shutters. blinds, shades... storm doors (all kinds of considerations).
Sadly... if you are interested in a "cheap" air-conditioning solution
this is the area where the cheap immediately becomes EXPENSIVE...
I personally hate having strangers in my house... but this is and area where getting a "utility ENERGY assessment" might be a good idea...
Then when you are assured your house is as good as REASON/FUNDS will allow...
THEN get estimates from A/C Vendors...
or
Hire an actual ENGINEER to get an idea of what your air-conditioning requirements are..?
Check the internet: you will be presented with an array of sheets, formulas... magic tricks..
It is important to know it is a CRITICAL DESIGN consideration... and has its on field of ENGINEERS.
Hope this helps
http://www.bing.com/search?q=air+conditioning+calculator&src=IE-SearchBox&FORM=IENTSR&pc=EUPP_
Buy Goodman Heat Pump Geothermal Heat Pumps Goodman Air Conditioner
No idea as you have not provided any details as to the BTU,hp or tonnage of the unit of the
basically a 10,000 btu will be adequate for a room 10ft x10 ft x 9ft high with one window not facing the sun
SOURCE: Cool air when running; warm air when compressor is off.
It sounds as if warm outside air is being drawn back into the room when the unit is not actively cooling. Portable units depend on room air to carry the heat outside, & therefore will not work properly if the room is too airtight. Provide a makeup air passage by leaving the door slightly open, & see if this helps. Use a room thermometer to see if your desired temperature is being reached. Note that if the wind is strong & coming from the wrong direction, it may not be possible to prevent warm air drawback.
SOURCE: Stand alone AC blows cool air but does not cool the room
send tank capacity.model mail me [email protected]
SOURCE: Unit Cools for two minutes and takes a three minute break.
I am having the same issue, the exhaust fan that blows the hot air out of the home is most likely not working. I am having a hard time finding a replacement fan motor
SOURCE: My Sanyo KS1211W split air conditioning unit does not cool
u r compressor is not functioning,sure u need the service technician
SOURCE: The 10,000 BTU portable room a/c unit is not running cold enough
Make sure your vent is closed. check the filter to see if its clean. If you run the a/c you can check your evaporator to see if you have condensation or does it freeze up?
Make sure you have your unit on early in the morning. If you turn it on in the afternoon the humidity might be too much and it will take along time to cool down.
Try those things if that doesnt work then you need a service call.
