The manual is on this link: http://engines.honda.com/parts-and-support/owners-manuals/GCV160 The manual depends on the serial number. It does not appear to have adjustable choke.
Gas filter might not run properly and it must be replace. If it gets bad enough the lawn mower might not turn on and in worse case gasoline could start coming out the air pusher.
You will need to know your serial number. They are free to download, but if you want to order a paper copy, you have to pay for it. Hope this helps and please don't forget to rate!
Drain oil from mower until proper level. Remove spark plug and pull starter rope several times to blow out cylinder. Spray starter fluid in cylinder pull rope several times to clean out. Replace fouled plug with new spark plug. Remove air cleaner, ensure no oil present, replace filter as needed. Clean air filter box with carb cleaner. Install new air filter reattach filter cover. Prime engine, pull starter rope 1/2 way 4 times to help prime, then pull starter rope fully up to 10 times to start.
Your filter base sounds like its clogged. It may be the case of the dirt dauber building a home in your filter base plate port that pulls air from the outside. Remove base plate and inspect for this problem.
a small flat surface...usually near the governor arm...the letter/number combination is "dot" stamped into the aluminum and kinda small....there will be a 4 letters and 7 numbers in a row...thats serial number...right above the 4 letters is 3 or 4 more, know as orientation numbers, that identifies usage...
