SOURCE: need rubber boot key contacts
Try wdgreenhill.com for the parts. They are in England but give great service and specialize in hard to find parts.
SOURCE: roland xp 50. everything works find except sound
Yes, he is full of it. For parts try Digikey.com, Mouser.com, and AntiqueElectronicSupply.
SOURCE: Roland XP 50 Head phone not working
Make sure that the level of the headphone out put is open. Make sure it is on manual adjustment and no auto level. And test your headphone on a other device to clear that your headphone is not broken. If all these options are correct you headphone pre amp of the XP 50 may be damaged or broken.
SOURCE: I have a 6 month old keyboard and have found that
Thisis hard to troubleshoot... The keyboard insynths are usually scanned as a matrix... If a disconnect diode has failed, then wrong notes can be triggered. There is USUALLY rows of the diodes on the circuit board where the keys hit. There are usually TWO contacts per key in order to sense key velocity. The lkey contacts are usually conductive rubber pills pressed against circuit traces under the keys. One sometimes needs to clean these contacts using 99% isoprophyl alcohol and Q tips.
I would do further testing of ALL combinations of notes played together to see if possibly any others show up as that could point to a particular failure.
SOURCE: roland fantom g8, problem, The last 2 octaves do
Read page 135 regarding the note range settings. Look also for keyboard split information. You may have the keyboard set to NOT play notes in the top octaves for the particular voice you are using.
