Have a Samsung Soundbar Model HW 550. Won't turn on manually. Have remote and change battery , soundbar doesn't turn on. I have plug it to differrent out let and still doesn't turn on.
Try manually to turn on , it doesn't function. Change batterry on remote, still doesn't work. Plug it to several outlets and still doesn't work.
The AH59-02330A remote came with the Samsung HW-D550 sound bar. It is not a universal remote control and will only control Samsung TVs. (The remote may also work with other Samsung audio devices, including the HW-DW551.) Samsung has the manual on the HW-D550 support page: https://www.samsung.com/us/support/owners/product/2011-2-1-channel-soundbar-hw-d550-hw-d551 . See page 10 of the manual for the limits of the remote. The current link to the manual is https://downloadcenter.samsung.com/content/UM/201102/20110201172514949/HW-D550-D551-USA-ENG-IB_cms_0126.pdf .
Since the HW-D550 was manufactured in 2011, the AH59-02330A remote probably doesn't work with all Samsung TVs built after that date. Manufacturers change codes fairly often. This means that newer universal remotes can control older devices. The reverse is never guaranteed.
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Because your TV is not Bluetooth-enabled and you are trying to connect it to a Bluetooth-enabled soundbar via Bluetooth. There are other ways to connect your TV to the soundbar:
1. analog AUDIO OUT (L/R) of your TV to the AUX IN on the soundbar (use a 3.5 mm.-to-RCA audio cable).
2. Optical OUT on your TV to Optical IN on the soundbar.
3. HDMI port to HDMI port (this may not work if your TV is not ARC compliant you have to try).
You get better sound quality with option 2.or 3. (if this one works for your TV)
Here is the link to download the soundbar's User Manual for help with the connections:
Here is a link to your product description. When you get to the web page, click on the "Manual" tab to read the user's manual to find out how you can connect your soundbar to your TV. HW H450 Wireless Audio Soundbar Samsung Home Audio
Use the audio out ports on the Sanyo to get audio to the Soundbar. You can use a single digital audio cable or the legacy RCA audio cables. The Audio Out ports are marked in white on the back of the TV. If it doesn't work, turn off the TV Speakers in the TV's menu.
Push in and hold the switch on the back of the subwoofer until the light starts blinking fast. Then, with the soundbar power turned off, hold the mute button on the remote. "ID SET" should show up on the display. Then turn on the soundbar, and the subwoofer should link to it.
