SOURCE: kenmore washer always makes lint on clothes
yeah check my four boxes and send me an e mail at [email protected] ref lint on clothes
SOURCE: Black Bits left in machine
It sounds like you may have trash in your lines.
This should fix the problem.
Please rate this solution.
SOURCE: where can I clean lint out of GE front-loader washing machine
You don't give the model number, so I can not know for sure. That being said, on newer front load GE washers there is a filter access right on the lower side of the very front of the machine. On many slightly older GE front load washers you will have to take the lower portion of the front panel off to find a filter access. On them, it is usually a bit to the right side, about an inch and a half round removable plug with filter attached. Be advised that when you take it out the remaining water from inside the machine and it's pump and hoses will also come out, so be prepared.
SOURCE: why does my washing machine leave lint on my
Most washers don't have lint traps, the dryers are expected to. In your type of top loader some simple traps would be located in the top cap of the agitator. They should be cleaned each load, but they only stop the bigger pieces.
SOURCE: how do you clean the lint catcher
if washer having difficulties draining the water, check out the DRAIN MOTOR PUMP , IT COULD BE CLOGGED with LINT & debris, locate at bottom side is a small motor where 2 hoses are connected , AJ
ehitlpool 8255E is the brand
