Sony Xperia Z1 Unlocked Black Logo
j
julie carlyon Posted on Jul 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My xperia z1 got a pop up saying google services framework stopped. i carn't get the message of the screen, any ideas
Tony Parsons
Level 3:
  • Sony Master 6,405 Answers
  • Posted on Jul 01, 2016
Tony Parsons
Sony Master
Level 3:
Answers
6405
Questions
Helped
1650735
Points
20272
Turn it off, leave 5 mins, then turn it on again.
castletech
Level 3:
  • Master 372 Answers
castletech
Master
Level 3:
Answers
372
Questions
0
Helped
102750
Points
1338
Have you tried a factory reset? (may need to backup everything first)
Link here: here
2answers
My Google services frame work notification keeps appearing, can't use my phone. How can I remove it?
Solution 1 - Update Google Play Services to the latest version. You can download from here. You may be getting an error because you have a very outdated version or the one you have is having a conflict/bug with the current Android version in your phone.
Solution 2 - Clear the Google Play Services cache. The Google Play Services app in your phone acts like a framework for all the Google and Google Play apps installed in your phone. You can try cleaning up its cache and see if that would fix the issue. This worked with one of our team members! Read these quick and easy steps :
Go to Settings > Apps.
Scroll to All apps and then scroll down to "Google Play Services" app.
Open the app details and tap on the "Force stop" button.
Then, tap on the "Clear cache" button.
Solution 3 - Clear the Google Services Framework cache. The Google Services Framework system app on your Android device stores information and helps your phone sync with Google servers - and keeps your Google Play Services up and running. This could be one of the reasons why you are not able to connect to Google servers using the app and keep getting the error message. Read these quick and easy steps :
Scroll to All apps and then scroll down to "Google Services Framework" app.
Solution 4 - Check your Internet connection. May be your WiFi network is blocking any of the IP addresses that Google use. You can also try switching the WiFi on or off on your phone - same with mobile data.
Solution 5 - This goes without saying, but may be a simple reboot of your Android phone/tablet could fix the problem.
Solution 6 - I hate to say this, but in the end, you might just want to install a custom ROM that is stable with no bugs.
Hope this helps
tip
How to Take a Screenshot on Sony Xperia Z1
1) Go to the display or the screen in your Sony Xperia Z1 which you want to capture.
2) Take a screenshot. Press the Volume Down button on the side and the Power button for about 2-3 seconds. Make sure that both the buttons are pressed TOGETHER, otherwise it won't work.
3) View your screenshot. You will immediately hear a clicking sound, confirming that the screenshot has been taken. You may also see the text "Saving your screenshot" on your phone's display during the process.
To view your screenshot, click on the screenshot notification in the notification tray or simply go to your Photo Albums and you will find the screenshots in a folder named "Screenshots."
Unfortunately Google Play services has stopped message appears on my mobile phone . How do I get rid of it as it comes up after every few seconds
Clear the Google Play Services cache. The Google Play Services app in your phone acts like a framework for all the Google and Google Play apps installed in your phone. You can try cleaning up its cache and see if that would fix the issue. This worked with one of our team members! Read these quick and easy steps : Go to Settings > Apps.
Clear the Google Services Framework cache. The Google Services Framework system app on your Android device stores information and helps your phone sync with Google servers - and keeps your Google Play Services up and running. This could be one of the reasons why you are not able to connect to Google servers using the app and keep getting the error message. Read these quick and easy steps : Go to Settings > Apps.
Then, tap on the "Clear cache" button. Google Play Services Has stopped message continually popping up on my...
2answers
How to Blocked my Xperia Z1
Unless you had it signed up or installed an app, you cant. You can have your service provider cut service to the phone, and that is about it. Is your GPS on?
Message keeps popping up....
Frequently, this happens do to a problem with your contacts or calender. It's a problem with syncing those items with your Google account or PC. If the problem is with one of these, you should try to manually synch the calender and contacts. (Go to Settings > Accounts & Sync > (Go to Gmail account). You'll see the option to sync the Calender, Contacts and Gmail. Select each one to manually attempt to sync the files. Determine which item is providing the error; you will need to clear the data from the problem application. (Note: back up your contacts first. Use the People > Menu > Import/Export > Export to SD card option if you can.)
Next un-check the sync option for the problem app (calender or contacts) under the Google Account > Accounts. Then go to Settings > Apps > Manage Apps > All and clear the data and cache for the problem app. (The contacts may be under the Running list.) Then re-enable the sync feature. If the calender is causing the error, you may need to erase and re-create your recurring item.
For some scrolling down to the Google Frameworks service in the Manage App > Downloads (or Running) menu then clearing that data. Then chose the "force stop" works to fix the problem. (However, this can put your cell phone into a factory reset state and may cause other problems.)
You will need to turn the cell phone off and back on before re-enabling the sync.
I hope this helps.
2answers
While going through the installation process it seems that the sw does not see the DVD RW drive. What can resolve this issue.
Hi ,
To ensure it's a problem with 321 , go to http://www.dvdfab.com/free.htm and download their free HDDecrypter and see wat happens . I have definitely opted for their products since a wile : just do the job fast and perfect . They have free tools , the rest is 30 days free trial .
Regards .
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
