Need a picture diagram on how to run engine wiring harness and picture diagram where the brackets bolts on to hold blower housing and other shild covers
SOURCE: I need a diagram of chassis wiring harness with electric clutch connection.
would need the model number but check the safety switches and trans switch
SOURCE: I need a close up picture of wiring harness for
I will get back to u asap with the photo and info. There is one sitting at the shop of a buddy who I help repair mowers. Try google or the john deer site too.
1 Park your Neon on a level surface. Engage the parking brake. Open the hood and loosen the bolt on the negative battery cable terminal and pull the cable from the battery.
Remove the Neon air filter by undoing the side clips and lifting the cover of the air filter off. Pull the air filter from the bracket. Undo the clip on the air filter hose and pull the hose off the inlet. Use a socket wrench to loosen and remove the four bolts holding the air filter bracket in place and pull the bracket from the engine
Locate the camshaft position sensor. It will be at the rear of the cylinder head, centered on where the air filter housing was about midway down. It will look like a black plastic square (4"x4") and have four bolts holding it to the engine.
Disconnect the wiring of the sensor from the wiring harness feeding into the car's electrical system. Press in the tabs at the sides of the connector and pull the two halves apart to do this.
Remove the four bolts holding the sensor in place and remove the sensor from the engine.
Clean the engine of any gasket material from the old sensor by scraping the surface gently with a paint scraper.
Install the new sensor by placing it in the same position as the old one, replacing the bolts and then connecting the wiring harness. Replace the air filter bracket, hose, filter and cover. Reconnect your battery and you are done.
