Delta & Single Handle Shower Faucet  Logo
D
Diane Sorensen Posted on Jun 30, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I replace a Delta shower faucet with a new one?
I have a delta shower faucet that is 40+ years old that is leaking and I want to install a new unit. I need instructions on how to do this please. Do I have to get in behind the shower stall?
Bill Boyd
Level 3:
Top Expert:
  • Delta Master 53,816 Answers
  • Posted on Jun 30, 2016
Bill Boyd
Delta Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11944933
Points
172802
Should not be necessary to get behind the shower stall as there should be a hole big enough to remove /replace the facet insert
call a plumber in as it may be corroded in place and may require specialist tools for the job
get a quote first
Testimonial: "Thanks Bill, appreciate your expert advice. Diane"
I instslled new delta single shower faucet ,the water is running for 5 to 10 sec even if the shower handle is in off position
Sounds like someone did not remove the plastic valve assembly before soldering the valve body to the copper piping.
That or the valve body needs cleaned out. It is common for debris to get knocked lose when doing installations on old plumbing.
I WANT TO REPLACE TUB FAUCET. IT IS SINGLE HANDLE-OLDER DELTA
It should be compable with a new delta if you replace it with one or you can get washers to rebuild it yourself. Delta are a real good faucet.
4helpful
Need to fix a leaking delta shower faucet and need to know how to take it apart. Single handle. only turns to left for on and farther left the hotter it gets,
find the set screw on the handle loosen and remove handle, remove locking ring (a tool to do this comes with the replacement kit that you can buy from hardware store) remove the ball. You now have access to the washers and springs remove old washers and springs install new. reassemble in reverse. make sure not to overtighten locking ring.
Water leaks from the shower head. I have a delta
You may want to replace the ball or cartridge whichever the case may be. Also be sure to use Genuine Delta parts as they will hold up much better than the aftermarket parts. I hope this helps.
1helpful
2answers
Delta 134900 handle Water coming out faucet and shower both
well the Diverter is not working it dose not matter the distance. when applied it should shoot the water to shower or tub if not working will come both.
4helpful
3answers
Leak in hand held hose, Delta In2ition
you must be missing a washer or gasket that goes in the hose end, of the hose try teflon tape,this is all your plumber is going to do.
1helpful
My Delta single handle shower faucet drips constantly
call delta and describe the round plate and the screw locatios. they can identify model. you need a new cartridge they costs $25-60. They may send to you for free.
Top Delta Home Experts
john h
Paul Carew
Paul Bade
Are you a Delta Home Expert? Answer questions, earn points and help others
