Prior FIXYA question:
http://www.fixya.com/support/t2766014-everstar_model_mpk_10cr_flashing_p2
Everstar Model MPK 10CR What does flashing P2 mean
Quoting:
Everstar Model MPK-10CR, What does flashing P2 mean?
I have a manual and it only talks about the error, P1, when the water container is for. Says nothing about P2. The unit will just completely shut off and then the red light is flashing and P2 appears in the window.
Posted by oyalajan on Aug 13, 2009
- oyalajan Aug 13, 2009
No, I do not add water to the unit.
zobs
P2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle Posted on Jul 21, 2010
- jerry1029 Jun 14, 2011
My unit runs for about 5 or 10 minutes then shuts down blinks red with the P2 error message. I read what has been said but there is no water built up in my unit. i removed the plug , nothing. it does not run long enough to fill up. any ideas?
gerald young Jun 12, 2013
my unit is flashing p1 my unit is flashing p1 what is wrong
w_benjamin
The filter that allows the water to get to the pump is clogged. Since the pump can't pump the water into the drain bucket, it fills the bottom pan up, the unit shuts down, and the P2 error code is then displayed. Posted on Jun 29, 2011
oyalajan254 Jun 30, 2011
Where is the filter that is full that is not allowing the water to drain into the drain bucket, and is it something that can be cleaned? w_benjamin Jun 30, 2011
It should be near the pump that pumps the water up to the drain bucket. Each model is different, on my Everstar it was located under the housing for the drain bucket. The back and front of the unit needed to be removed, then the housing for the drain bucket needed to be removed. Not that hard, but a lot of screws. Take it out, then clean it with some dish washing detergent.
