10-12 years old.
SOURCE: Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
SOURCE: water leaking from below dishwasher from below during cycle.
If you cannot see anything around the pump assembly there are a couple places where the pump attaches to the tum with seals that could leak, Look where the rack wheels attach to the tub also. A mirror and a flashlight are real handy for this. Depending on the cause for the leak will determine if it is worth repairing or repairable. Life expectancy of dishwashers is 7-10 years. Eric
SOURCE: How to Clean Glass inside door of Inglis Royal 100
The door actually lift out if you grab it on either side and lift up, the hinge will come up and you can lift the door off. Then, it's just a matter of taking the screws out around the edge and you can get the glass out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: 1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
SOURCE: bosch dw shu043 dishwasher stopped working in middle of cycle
Hi and welcome to Fixya. Based on your post, I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line. Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair. This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance". The end result is no power to the controls. Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you. Good luck. Macmarkus :)
