I have a Palsonic Digital TV 2 years old Have tried tuneing it in aoto tune when it comes to the end where it says ok or cancel I press ok but it doesn't go through process
SOURCE: Digital tuning
You'll need to go into service mode and do a factory reset.
To enter service mode you'll need to press these buttons on your remote in the following order:-
Standby-info-menu-mute-standby.You'll need to do it fairly quickly and be patient it doesn't always go into it first time,don't press and hold the buttons.
The service menu should appear on the screen.Use the up /down cursor to scan down to option number 12 (factory reset)and then press the right cursor wait will appear on the screen and the set will go to standby(don't worry this is normal)
Reboot the set and retune and all should be well
SOURCE: problem with tuning digital channel
I would believe from what you said, you have solved your problem. You will need a UHF antenna to receive the signal. Walmart or Radio Shack has a great amplified antenna that will work for you.
Mike
SOURCE: I have re-tuned my tv but it does not pick up any channels
Maybe you have to tell it to look for digital channels, not analog.
SOURCE: how do i tune in a 3 year old philips hd flat
my philips 32 inch flat screen doesnt give me freeview anymore when i scroll down to digital tuner i just get a blue screen
SOURCE: try to do automatic tuning and manual tuning but
Please email [email protected] with your full model number to confirm if the product is one of ours so we may assist you further
