Luxor 19822 COB Logo
I
Ian Butterworth Posted on Jun 29, 2016
My tv will no switch on
Will not switch on power indicator Flashes blue light
A
Anonymous
Can I suggest ....if you have not already done so.....Switch off from the power button. Switch off from wall socket. Leave for a few minutes. Plug in..switch on....Make sure if you have a remote the batteries are OK..renew if you need to.
My TV does not work, pressing the remote control on the blue light flashes
From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Power comes on but no tv just a flashing blue light to indicate power
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Tv won't come on blue flashing light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
2answers
Jvc no power when plugged in
you tube might have blown ouy that's a big problem.Next time make sure you plug your TV in a surcharge protector
1helpful
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
My phillips 60 inch tv 60pl9200d/37 wont turn on the power button flashes blue
Look in the manual. (Page 4)
Turn the TV on From main supply: Ensure that the main supply is turned on. A blue indicator light on the front of the TV lights up. When the TV is turned on by the main supply, the blue indicator light will blink for 45 seconds. This is the lamp's start-up period. When the light goes off, press the POWER button on the remote control or power switch. Press POWER to turn on the TV.
http://www.retrevo.com/support/Philips-60PL9200D-TVs-manual/id/633ag423/t/2/
Telephone number Philips Customer Care Center: 1-888-PHILIPS (744-5477)
Top Luxor Televison & Video Experts
Paul Bade
NOEL
NOEL
Are you a Luxor Televison and Video Expert? Answer questions, earn points and help others
