SOURCE: washing machine
What actually will happen over time is the stainless steel retianing hub and nut diseningrate and the tub becomes loose. Then the spin cycle will destroy the top balancing ring. When this happens - the washer is junk - not worth repairing.
Before that thou - other mechanical problems can happen, like u-joint breakage. These washers are absolute junk.
SOURCE: Whirlpool front loader washing machine
you see plastic shavings??? thats part of the front tub assy, not a very fun part to change call a professionnal for that one. in the meantime id pop off the lower acess panel and make sure all 4 of the suspension rods are in place and not causing the tub to lay foward and rub
SOURCE: Kleenmaid top-load washing m/c leaks water and then smokes!
It sounds like you are leaking from the bottom of the unit. If you are leaking at the top then you need to check the water inlet valves, and also the drain pump and all water hoses. This doesnt sound like a seal issue.
SOURCE: We have a Miele W830
Although this answer is obviously not current any more I thought it may help others. We recently had the same problem with our machine. The clamp holding the hose to the detergent drawer became loose and the hose came off, allowing water to pour right down to the drain pump area. By undoing the 3 screws behind the detergent drawer + the 3 bolts around the door, I was able to open the front of the machine and tighten the hose clamp.
ozfix
