If one of the colour catridge is empty or damaged, willthe printer will not do the printing jobs at all?
It is not at all printing any job. But the error message is only magneta catridge is empty repalce it. Why it is not printing the black and white printing job ?
Re: If one of the colour catridge is empty or damaged,...
This might be the issue.... The paper still has to pass through the magenta even if its not used but being empty it might not register the toner hence not allowing you to print at all.
You haven't indicated make and model of your printer. Now, MY HP has been acting really weird when the head was damaged after a refill. If your printer has a color and a black cartridge, check them removing one at a time. Sometimes after removing the damaged cartridge, the printes works, so all you should do is buy a new cartridge,
You need to find the Color Options Features Tab; choose greyscale or Black Only.
Follow these steps to change the print settings for a single print job in Windows 7.
1.Open the document that you want to print. Click File , and then click Print . The Print window opens.
2.Click the button that opens the Properties dialog box. Depending on the software program, the button might be Properties , Options , Printer setup , Printer , or Preferences .
3.In the Properties dialog box, select the print properties for the current print job, and then click OK .
Follow these steps to change the default print settings for all print jobs.
1.On the Windows taskbar, click the Windows icon, and then click Devices and printers .
2.Right-click the printer icon for your product, and then click Printing preferences .
3.Select your new default print settings, and then click OK .
please use the colour printer ? and you have a colour printer
then your printer job is colour ? your printer cartries is colour & w&w ?
if colour ? then fristime you aply a print and so the print page is ok and so the previue the page in colour job if yes is ok and other no then
print page and in prperty selectand cleck and go immage in colour select the colour and aply the ok and give a print is ok
just fill up all the catridge bcoz in colour printer anyone of them is not fill up the printout not coming properly , after filling the catridge just check
Go into Printers, Properties, Printing Preferences, then Black Ink Only. If you make that the default, it will automatically print black ink with you click on the printer in the toolbar. If you want to print one document in color, click on File, Print, Properties, and set it for color for that one job only. The default of Black Ink should stay the same.
