SOURCE: 1998 Cavalier No Spark in cylinders 1 & 4
ignition mod. grounds,pcm or timing belt could all be it but, I would have to look at timing first.
misfire caused by leaking in the intake valve you must chek it , or may be your car is working rich that means fuel - air mixture is not on the right ratio so check your oxygen sensor
SOURCE: 2000 Kia Spectra
http://www.kiatechinfo.com/index.asp
Good source for Kia its free to register NO STRINGS
SOURCE: 2005 Jimmy 4X4, 4.3L, P300 multiple misfire. Have
Try some injector cleaner in the fuel--there might be some water in the fuel also. Check the air cleaner.
