Hi Brian Harper, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?Hi Brian Harper, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
this sounds like the internal power board or video board has gone bad, the capacitors have probably gotten too hot and started to leak, like an old battery (they contain similar substances), when cheap capacitors are used this happens sooner rather than later, just like when you use cheap batteries. this could be fixed easily if you are good at soldering, otherwise you should send it to be repaired professionally.
This is a common issue, the power supplies in LCD monitors fail prematurely. (if your monitor has an internal power supply) , Double check all your power connections, but it sounds like the internal supply is toast, (its a simple capacitor replacement to fix, but cost to do this job seems to always outweigh a new monitor purchase) sorry to be the bearer of bad news.If you find my answer helpful albeit poor news, please use the thumbs up feedback.
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages. Good Luck!
