Not knowing which model you have, here are the instructions for my model. Perhaps yours is the same.
"The Automatic Shutoff
Time can be programmed anywhere from immediate shutoff after completion of the brew cycle up to four hours. When the coffeemaker shuts itself off, two tones will sound. Two hours is the default time. The 0:00 setting shuts the unit off immediately after brewing is complete.
To check the current setting, press and hold the On/Off button and the Automatic Shutoff Time will be displayed.
To change the preset time, press and hold the On/Off button until the red power light and LCD display begin to flash. This signals that you have entered the Set Automatic Shutoff mode.
Press the Hours and Min buttons to scroll forward through the digits until desired time appears. The first setting which appears is preset at 2:00. When it's at 4:00, the next press key of Hour will roll back to 0:00, since four hours is the maximum Automatic Shutoff setting. Pressing and holding either button will allow you to scroll continuously, slowly at first, and then to accelerate to the rate of about three digits per second. As the desired time setting approaches, release the button and then press repeatedly to advance one digit at a time. The Automatic Shutoff Time (ASO) may be 8 9 programmed either before or during coffee brewing. You may also re-program the ASO time when brewing has been completed. If you do so, the Grind & Brew™ will automatically account for any time that has already elapsed after brewing. For example, if you set the ASO for 40 minutes and 25 minutes have already elapsed, the Grind & Brew™ will shut off automatically after 15 minutes (40 minutes minus the 25 elapsed equals 15 minutes)."
Mine doesn't have a specific clean cycle, but to decalcify the unit, add 1/2 vinegar to 2/3 water in a full cafree and run it through. If it's really calcified, turn off about 1/2 way through and let it set for an hour. Then turn it on and finish, Remember to run a pot of clean water through the wash out the vinegar taste.
SOURCE: GE 169164 coffee maker problem
*** HOW TO RESET THE GE 169164 COFFEE MAKER ***
After endless online searches yielding the same results (nothing useful), I figured out how to reset this coffee maker.
While coffee maker is plugged in and the evil little blue light is mocking you relentlessly, press and hold the 1-4 button and the TSB button simultaneously for 3 seconds or so. This will cause the device to exit it's error status and allow normal use of it.
SOURCE: how do i use cleaning cycle on ge self cleaning coffee pot
You can find the instructions in this pdf file the link is http://www.gehousewares.com/products/200836153329360.pdf
SOURCE: Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
SOURCE: our coffee maker is only brewing half of the
Run a 1/2 pot of vinegar through it 2-3 times (I reuse it) and then run water 1-2 times to get the vinegar smell out. This cleans the mineral deposits from your water that are clogging it.
