SOURCE: From 1-7 on the coffee grinder, which is the finest grind.I Hve misplaced my manual
1 would be the finest. I wouldn't recommend going under 2 though.
You risk clogging your grinder and machine under 2. There's also a dosage control when you open the door on the side. + means a bigger dosage or puck.
Hope this helps.
SOURCE: saeco magic de luxe grinder problem
Hi Cindy,
Make sure you not get any water in the grinder, if you get water in the grinder then it bean smeary and will not grind the beans.
You have to clean the grinder if you get any moisten in it.
/Mirran
SOURCE: saeco magic de luxe espresso machine
Ok, so you can download a new user manual for your saeco coffee machine here http://www.coffeeshrine.com.au/user-manuals/
let me know if you have any specific question following this.
SOURCE: Need Instruction Manual for Saeco Magic Comfort Plus
http://products.saeco.com/index.asp?id_paese=7
follow the link to the instruction manual
SOURCE: Saeco Vienna Deluxe leaking problem and grinder problem
I would repair it, it sounds like the grinder needs to be adjusted (burrs may be dull), and the leak on the bottom may be coming from the small drain hole on the back of the brew chamber. If you remo;ve the chamber you will see the white water valve that the chamber connect to, if you look below the white valve the small chamber in there will be filled with water, below that there is a small discharge use a stit stick or paper clip to clear hole.
