Have a Yamaha RX-V371 AV Receiver which sits between a media centre, cable TV box and a samsung tv. Everything connect via HDMI, ie. Media Centre -- AV Receiver -- TV and the same for the cable tv box. Of late I have found that when switching the AV Receiver from 1 HDMI input to the other that the audit and video signal comes on and off intermittently. I get flashes of sound/video. It will attempt 4-5 times before it finishes with a blank screen I.e. no audio or video As I switch backwards and forwards between the two HDMI inputs the flashes of audio and video on each HDMI input get longer and longer until finally I have a consistent signal for audio and video and it will be fine until I want to switch to another input - which send me backs to the beginning with the intermittent signal. the problem is getting progressively worse. When it first started happening it might take 3-4 minutes to get a solid signal - now its a 20 minute effort. Its so bad now that I have removed the AV receiver from the middle and now only have Media Centre -- TV and there is no signal issue but have lost all 5.1 surround sound. Any idea where the problem is and whether or not its repairable?
SOURCE: Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
