Question about Vehicle Parts & Accessories
How to reprogram excalibur omega147 remote - Vehicle Parts & Accessories
My Excalibur echo remote will not start my Chrysler 300 anymore, is there a reset or reprogram I can do?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Feb 09, 2016 | Excalibur Echo3 2 Way Remote
Put new battery in my Excalibur remote,now it doesn't work and the keypad stays lit
Let it sit for a day without the battery. Push all of the buttons on remote while battery less to discharge any and all caps.
If it still does not work with new batteries then the RC has gone to remote heaven and needs to be replaced as I had to do.
Mar 12, 2015 | Excalibur Televison & Video
Why is their blue LED lights blinking on the receiver to my Excalibur remote starter
You need to turn off the power to it for thirty seconds then plug back in
Feb 11, 2015 | Excalibur Televison & Video
Excalibur alarm
hi
when you press the off button you have to remove the plastic cover under the steering wheel
remove the fuse from the red wire which is the power wire to the alarm
this will disable the alarm but you will be able to use your car
aries
Sep 15, 2013 | Vehicle Parts & Accessories
Will the excalibur touch remote work with another excalibur alarm i dont have the alarm model number but do have the alarm that i have on my car remote fcc # and it is a remote start alarm too the fcc...
The Touch remote can be used with any Echo compatible systems. These systems can be identified by their model numbers. Systems ending in E, EDP and EDPB are Echo compatible.
Dec 11, 2010 | Vehicle Parts & Accessories
Remote starter stops working every few months, I was bringing it in to have it reset every time but shop is no longer open. I would like to know how to reset the unit myself.
Use this procedure to reprogram the remote transmitters
1. Turn "on" the ignition.
2. Press the Valet Switch 5 times and wait for horn confirmation of entry into programming mode.
3. Press and release the "Lock" transmitter button on each remote to be coded (one at a time).
4. The system will respond to each with an audible confirmation.
5. Turn "off" the ignition to exit program mode.
The unit should retain the transmitter codes almost indefinitely and should not require reprogramming periodically. I suggest that you call Omega Research and Development, the makers of Excalibur, to see if your unit can be replaced. Their number is 800-554-4053 and their is www.caralarm.com
Nov 10, 2010 | Excalibur RS-310-EDP Remote Start Keyless...
My battery went dead and now my remote doesn't work and the keyless entry doesn't work either.
reprogram remotes turn ignition key to on position push valet 5 times then hit the lock button on remote
Jan 04, 2010 | Excalibur RS-310-EDP Remote Start Keyless...
Excalibur car alarn
i have a Excalibur AL1830EDPb Remote Start Alarm 2 Way. I only have a range of about 60 ft from from the car, should this not be about 3000 ft
Jul 26, 2009 | Excalibur AL1810EDP Remote Start Alarm 2...
Vehicle Parts & Accessories Logo
2,321 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
